Salta al contenuto principale
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
83 Domande Visualizza tutte
Is it possible to increase the ram on the ti-84 plus ce
is it possible to solder better ram on my ti-84 plus ce , i have good slodering skills , and i looked up the processor and it says the speed will increase with more ram up to 150mhz
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione Prescelta
To elaborate on Austin’s answer: Not only are they soldered, but even if you have the experience to desolder the RAM and replace it with compatible, better RAM; the calcuator’s operating system couldn’t even utilize it. TI designed the OS to rely on having only 256kb of RAM. The same goes for the Archive storage as well. You wouldn’t get a CPU clock boost either.
If you want to increase the speed of your TI 84 Plus CE, there are a few programs that can help. One such program is the Advanced Wait State Change[|r] I wrote that reduces the wait states of the calculator and can make it up to 30% faster.
Punteggio 4
Unfortunately no. All components are soldered onto the motherboard and cannot be swapped like normal computers.
Punteggio 3
Aggiungi la tua risposta
Brayden S sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 74
Tutti i Tempi: 5,994
