Salta al contenuto principale
Samsung Series 5 3G Chromebook. Questo portatile ha un display da 12,1" Super Bright ad alta risoluzione, antiriflesso, ideale per la navigazione web.
Where's Developer Mode Switch?
The Developer mode switch is supposed
to be in the battery compartment or
behind a removable panel.
It's a very important feature and you
don't mention it all. where is it
located at?
Questa è una buona domanda?
Punteggio 1
1 Commento
mine was a device that had no switch near the sim , instead it was inside the small hole in the case to the right of the power button
da Condividi
Aggiungi un commento
3 Risposte
Soluzione prescelta
The dev switch is accessable without opening the device. It is on the right hand side of the device behind the SIM slot cover.
Edit: You can see it right below the SIM slot on the Step 14 teardown picture.
Punteggio 5
2 Commenti:
I Have a chrome book and have looked behind the panel where it is supposed to be and there is not a switch there, the hole is but there is not a switch to use?
Any ideas?
da Condividi
robert clench, did you confirm this by checking the image of the teardown?
da Condividi
From what I've read, the developer switch is only on the CR-48 (Prototype/Developer Chromebook) It isn't found on retail models.
Punteggio 1
1 Commento:
Not according to what's stated in here. http://goo.gl/b2Fl2
Shell access is only available in Dev mode, if it's not included, a lot of people are going to be angry.
da Condividi
The Dev Switch Is On The Right Side Of The Unit, Where The Sim Card Slot Is Located, It's A Switch That Can Be Toggled With A Pin (Paper Clip) Or The Tip Of A Pen.
Punteggio 0
4 Commenti:
So you are confirming what "no way" answered in June of 2011 correctly. Good Job ;-)
da Condividi
Wow apparently so , I guess that's what happens when you don't bother to read all posts. My apologies.
da Condividi
Yup, happens all the time ;-)
da Condividi
how do u use the switch
da Condividi
Aggiungi la tua risposta
William Greene sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 24
Tutti i Tempi: 11,576
