Salta al contenuto principale
Il Moto E4 Plus, noto anche come modello XT1774, XT1775, XT1776 o Moto E Plus di quarta generazione, adotta un ampio schermo HD da 5,5" e una scocca metallica dalle linee arrotondate. Ha batteria da 5000 mAh, rivestimento idrorepellente e sensore impronte digitali.
31 Domande Visualizza tutte
Part number for the USB Charging Port on a MOTO E4 Plus XT1775?
I can’t seem to find the replacement part for the USB charging port adapter on my phone. The adapter on my phone has the connector for the vibration motor on the bottom of the adapter board. Does anyone know the correct part number or where I can obtain the part?
Thanks for any help you can provide,
James
Questa è una buona domanda?
Punteggio 3
1 Commento
Ebay has them
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
@jgsj Motorola is a bit stingy with their manual and part numbers. However if you do a search on XT1775 charging port, you’ll get lots of hits that will have the board. Check places like this or even on here. Here is the guide for the repair Motorola Moto E4 Plus Charging Port Replacement
Punteggio 2
3 Commenti:
neither one of these links goes to the right part for this phone, and if you search for xt1775 they don't pull up anything that's an exact match. I'm having trouble finding it too. May just have to buy a parts phone to get the right one.
da
Tony Hernandez do a search for PH-CF-MT-00024 and do not depend on images. Those are usually just representations. Always contact the vendor.
da
This the UK version. The US version has the cable connections reversed. I cannot find a full replacement for the US version. This brings the only replacement option to be soldering in a new port connector to the existing board
da
The site that has the part you are looking for is www.mobilesentrix.com. See the SKU: 107082016634. They are out-of-stock as of 8/20/2019. If and when you go there you'll also see the “European/International version. This is what almost everyone says this is the proper part. It is NOT. I've been searching for the proper, US Version for several weeks now…No cellphone for me, mine has been dead since then.
Punteggio 0
The US version of this charging port is a hard part to find.
The Mobile Defenders parts store (www.mobiledefenders.com) also lists the charging port daughter board for the US version of the phone. It is out of stock right now, but is expected to be back in stock on February 3rd, 2020. It is their part number 01019394001W
Here’s a link to the item on their site:
https://www.mobiledefenders.com/mobile-p...
I hope this helps!
Punteggio 0
Aggiungi la tua risposta
James St. John sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,285
