Salta al contenuto principale
Nel giugno 2017 Apple ha aggiornato il MacBook Air 13" con un nuovo processore Broadwell Intel Core i5, che ha permesso di aumentare leggermente le prestazioni e la durata della batteria.
423 Domande Visualizza tutte
MacBook Air (2017) with replaced SSD freezes after wake-up
Hello!
I have a quite new MBA 2017, I got with 128GB SSD.
I have replaced the SSD with the Apple (Samsung) 512GB, which worked fine with my previous MBA 2014.
I have this problem for quite some time already, went through PRAM and SMC reset, reinstalled Mojave from scratch… Nothing seems to work…
Is there anything I can do? Or is there at least the reason for this issue?
Thank You! Milan
Update (01/26/2019)
My SSD is Apple/Samsung.
Model: MZ-JPU512T/0A2
S/N: S18YNYAD637717
512GBSSUAX 655-1805A *DN132510AWDF754AK*
As per my reading of The Ultimate Guide, it doesn't seem that there are compatibility issues.
Also, MacBook Air works perfectly smooth apart from freezing.
Thanks again…
Questa è una buona domanda?
Punteggio 1
1 Commento
i have a original ssd chip but still facing this issue i already tried all of thiat method
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
First Review This Guide: The Ultimate Guide to Apple’s Proprietary SSDs To make sure you’ve go the correct SSD for your system. Your MacBook Air needs a PCIe 3.0 x4.
Punteggio 2
Aggiungi la tua risposta
Milan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 197
