Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
I want to replace my 2011 iMac harddrive to resell it
Hello,
I have a 2011 27” iMac with a dead HDD. I want to replace the drive and then resell the system.
My question is, which HDD would be the easiest to install? Can I just buy this kit and replace the SSD?
OWC SSD Upgrade Bundle for 2011 iMacs, OWC Mercury Electra 250GB 6G SSD, AdaptaDrive 2.5" to 3.5" Drive Converter Bracket, in-line Digital Thermal Sensor Cable, Installation Tools
Or, do I need to buy an adapter or should I just go ahead and buy a HDD? Can I buy a regular Western Digital Blue 1 TB and install that?
Thank you!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Here’s how to change it:
Installazione dell'SSD nell'iMac Intel 27" EMC 2429
To avoid the additional expense of an OWC thermal sensor (necessary when changing to a non-Apple drive), go to eBay and buy a used Apple OEM 1 TB drive and just drop it in. Upgrading the drive before selling, seldom adds any value.
Punteggio 2
1 Commento:
Thank you !! The hard drive is actually dead, that's why I am replacing! Any tips on finding the best kit to remove the screen/reinstalling it ?
da
Aggiungi la tua risposta
Brandon Tirre sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 228
