Salta al contenuto principale
Modello A1286. Lanciato nel febbraio 2011 / processori quad-core Intel Core i7 da 2,0, 2,2 o 2,3 GHz
586 Domande Visualizza tutte
How to get my data from hdd?
Hello,
I have MacBook Pro 2011 and after the logic board problem I can't log to my MBP ! I have very important data on it!
Now I have a PC with windows 10 how I can get my data again ?
Note: The MBP had a password when it's work properly.
Questa è una buona domanda?
Punteggio 0
4 Commenti
This just make internal hard disk as external hdd I have tool like this.
The problem is: I can't see my files in hdd Because the OS is different.
Thank you for answer.
da
Hi @aligraphics ,
There's info online that shows how to read mac files using Windows. ;-)
da
Thank you so much, I made it before this but I can't see my data only system files exist!
da
Hi @aligraphics .
You can try this and see if it works. It says that there is a free 5 day trial before you have to buy it ;-)
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Buy the enclosure here and transfer your MacBook Pros hard drive into the enclosure. Plug the enclosure into your new computer and you can retrieve the files thru there.
https://www.amazon.com/AmazonBasics-2-5-...
Punteggio 0
Aggiungi la tua risposta
Ali sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 58
