Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
774 Domande Visualizza tutte
How do I replace the CPU tapes on the MacBook Pro?
I have a 15” Apple MacBook Pro from 2015 with ForceTouch Trackpad. I was changing the thermal paste for the CPU and I ended removing the black tape that’s around the side of the CPU. The black tape was covering some CPU components.
It looks like I need to replace it, but with what? Should I use the typical black electric tape or use something else?
I’m in the UK, so if you have suggestions, please let me know.
Here is a picture to so you guys can see what I mean by the black tape.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Risposta Più Utile
I’m looking at step#9 of the heat sink replacement guide and don’t see any tape. Would you post a photo of what you are seeing.
Sostituzione dissipatore MacBook Pro Retina 15" metà 2015
Punteggio 2
You can use the yellow kapton tape in place instead of the usual black plastic tape they put on there.
Punteggio 0
Thank for you reply, guys. @mayer I’m talking about the black tape around the CPU. From the photo you attached, there is thermal paste on the reflective part, which is the main CPU and iGPU, the rest is black tape that is stuck on around the chip to protect the other chip components. I highlighted into this photo to show you what you mean.
I also attached another photo of the stock 4770HQ without the black masking tape, and I drew on it to show you what it looks like with the masking tape.
Punteggio 0
3 Commenti:
OK. i just have never taken that tape off. It's probably there to prevent excess thermal paste from getting on other components. Ben is probably correct in using Kapton for replacement.
da
Cool Thank you! Also, thank you for taking the time to reply and help me out. It means a lot! :D
da
What did you end up doing as your final solution? I’m planning on using a tape like Kapton tape to cover the other components
da
where i can get these tape ?
Punteggio 0
Aggiungi la tua risposta
dino sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 442
