Salta al contenuto principale
La revisione del 2016 di Apple alla propria gamma di laptop indirizzata agli utenti professionali. Adotta un display Retina da 15" e 2880 x 1800 pixel, processore quad core Intel i7, opzioni SSD da 256 GB, 512 GB, 1 TB, 2 TB, 16 GB di RAM e tastiera dotata di Touch Bar. Rilasciato a novembre 2016. Modello A1707.
260 Domande Visualizza tutte
Cracked MacBook Pro 15 bottom bezel
I crakced my macbook pro’s bottom bezel, first day display was fine.. now a black strip appear..when tap on that cracked portion. That area color is reverting the color of actual screen..
So costly to replace entire screen.. please help..
Update (01/12/2019)
Is it possible to change chin plate? When clicking there color is inverting with black color when tap on that cracked portion. That area color is reverting the color of actual screen.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Same thing happened to me.. so gutting. Happened within months of getting the device. Can’t afford to repair it
da
Aggiungi un commento
2 Risposte
Review this guide: MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement. You’ll need to order the plate from eBay Front Glass Bezel LCD Logo Cover Trim MacBook Pro 15"
Update (01/12/2019)
OK, Thats not good ;-{
The chin plate covers the edge of the LDC panel’s fragile contacts. Your LCD panel is also damaged! You can’t do anything to fix it other than replace it. Unlike the older models this series as the T-CON board mounted in the main case so more lines are needed to move data from the case to the lid as you can see here:
You have no choice here you need a new display assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly Apple P/N 661-08031
Immagine MacBook Pro 15" Retina (Late 2016-2017) Display Assembly
Prodotto
$507.99
Punteggio 0
4 Commenti:
Does it will help to get my display back to normal? I mean that black area..
da
OK, thats a different issue! This only addresses the chin plate damage.
So your screen has an issue too! Post a picture or two here for us to see Aggiungere immagini ad una domanda
da
If the bezel i cracket, will it interfiere with the brigtness of the display or colors? Im thinking og byeing at mac with a crackey bezel.
da
@Lars Ulmer - It could! The ribbon cables are just behind the plate so they could become damaged. Review the images in this guide MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement
da
There are ribbon cables connected to the screen that hide behind that small chin bezel. When you smashed the bezel in you must have hit one of those cables…
Punteggio 0
Aggiungi la tua risposta
max wright sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 8,973
