Hi @rivenroe ,
Has it ever worked OK?
I’m wondering if there is a problem with the pressure sensor in the cooker.
According to the user manual:
When the Multi-Cooker is gaining pressure, “HEAt” will appear on the Display Screen and the time will not count down. When pressure has been reached, “HEAt” will disappear on the Display Screen, and the time will begin to count down.
Have you tried adjusting the pressure to see if this resolves the problem?
To Change the Pressure: You can change the pressure on certain pre-set functions before cooking begins by pressing the PRESSURE ADJUST button before pressing START/STOP.
If it still doesn’t work, how long have you had the cooker?
There is a 12 month manufacturer’s warranty on the product. If it is still within the warranty period, contact the manufacturer’s consumer affairs department as per the warranty card that came with the cooker (or see the manual) as to what to do to make a claim for a warranty repair or replacement.
Votato
Annulla
Punteggio
3
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
1 Commento
My digital counter not working can this be repaired
da threadgoldn
