Ipad does not charge battery
Goodmorning everyone. As for object my ipad does not recharge the battery. When you connect the power supply on the screen, the looped charging logo appears. What can it be?
Questa è una buona domanda?
Check that the charger you’re using gives you at least 2A, if you are using a smaller charger such as that of an iPhone the iPad might bootloop forever. Same thing happens if the battery is dead and unable to take charge. Last possibility is the iPad charging circuit is faulty but since that requires microsoldering skills should be considered as a last shore. Don’t let the Ipad bootloop in any case as that might corrupt the Nand chip and make things worse.
Buonasera, purtroppo è arrivato al 42% enon carica più... avete idee?
Odds are yet the same, a faulty battery or faulty charging circuit. Unfortunately there's no way to tell exactly without further testing.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 69
4 Commenti
How long are you leaving it plugged in for? If the battery is completely drained, it may take a while before it has enough power to boot.
da Ian
Now I try to leave him in charge. The strange thing is the looped charging logo.
da Fabio Colombo
Do you have a PC or a Mac? Are you using a charger or a computer USB port?
da mayer
I'm using its original power supply. Now it is completely discharged and leaving it on charge seems to have broken down .. let's see what happens
da Fabio Colombo
