Salta al contenuto principale
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
559 Domande Visualizza tutte
Ipad does not charge battery
Goodmorning everyone. As for object my ipad does not recharge the battery. When you connect the power supply on the screen, the looped charging logo appears. What can it be?
Questa è una buona domanda?
Punteggio 0
Commenti:
How long are you leaving it plugged in for? If the battery is completely drained, it may take a while before it has enough power to boot.
da
Now I try to leave him in charge. The strange thing is the looped charging logo.
da
Do you have a PC or a Mac? Are you using a charger or a computer USB port?
da
I'm using its original power supply. Now it is completely discharged and leaving it on charge seems to have broken down .. let's see what happens
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Check that the charger you’re using gives you at least 2A, if you are using a smaller charger such as that of an iPhone the iPad might bootloop forever. Same thing happens if the battery is dead and unable to take charge. Last possibility is the iPad charging circuit is faulty but since that requires microsoldering skills should be considered as a last shore. Don’t let the Ipad bootloop in any case as that might corrupt the Nand chip and make things worse.
Punteggio 2
Commenti:
Buonasera, purtroppo è arrivato al 42% enon carica più... avete idee?
da
Odds are yet the same, a faulty battery or faulty charging circuit. Unfortunately there's no way to tell exactly without further testing.
da
Aggiungi la tua risposta
Fabio Colombo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 44
