Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1185 Domande Visualizza tutte
Black screen on boot after replacing the top lid
I got this MacBook Pro Early 2015 model, The screen is messed up, it still displays picture just the right side is cracked. I ordered a replacement screen and installed it.
On boot its black no display. If I close the lid the Apple logo lights up, then I re-open the lid and the display is fine. If I restart with or without the power adapter it boots to a black screen. I tried clearing the PRAM and EMC. Same issue.
So i reinstalled the original screen and it displays the picture right away just like it should.
What am I missing?
Running Mojave
Update
I did that as instructed same behavior Here are 2 vids i just upload to youtube. I put the original screen back on. Took a video of it then Installed the replacement and took a video of it.
Oringal Screen: https://www.youtube.com/watch?v=zMoNKmnT...
Replacement: https://www.youtube.com/watch?v=a-zvgMXE...
Questa è una buona domanda?
Punteggio 3
3 Commenti
Where did you get the display and the P/N you used? Also did you replace the full assembly?
da
Well, the part number is the correct one for your system MacBook Pro 13" (Early 2015) Display. But I think you got this one MacBook Pro 13" (Late 2013-Mid 2014) Display. Which explains why your display is not working correctly.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Double check that these:
are connected properly. You can find the order in step 8 of this guide. Also double check the the LCD cable is connected properly to the screen. Sometimes if the connection isn’t solid this can happen. After all that power cycle the MacBook
Punteggio 2
1 Commento:
Can you get a replacement?
da
Aggiungi la tua risposta
mikebarkas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 253
