Salta al contenuto principale
Processore quad core Intel Core i7 da 2,4, 2,7 o 2,8 GHz (3,8 GHz con Turbo Boost) con 6 MB di cache L3.
274 Domande Visualizza tutte
Right-sided ports not working
I recently dropped my early 2013 Macbook Pro (15”, retina) a week ago. Following that, everything worked for the first 1-2 days, then the ports would sometimes work, and now they aren’t working at all.
Reading previous posts (Ports on right side have stopped working, SD Card and USB), it could be an I/O cable issue, and my question is whether that could still be the case if it was intermittently working?
Thank you!!!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
The cable might be the problem. Use this guide to reseat/replace the I/O Board Cable MacBook Pro 15" Retina Display Early 2013 I/O Board Cable Replacement
Punteggio 1
Aggiungi la tua risposta
Eric Lake sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 178
