Salta al contenuto principale
1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
MacBook will not charge.
I have tried a new charger, but it’s the same. Sometimes I get a solid Orange light, sometimes green. It stays on 0 percent, and doesn’t move.
When I look at the battery statistics it says that the capacity is 5246 and 627 cycles.
Any ideas?
Update (12/19/2018)
The light is now green but still no charge. Its solid green.
UPDATE (07/19)
Sorry to resurect this but I’ve only just got around to a new I/O Board attempt.
Was strange as before it was always on 0 - 1 percent and not charging, replaced the I/O board and now its on 20 odd percent, still not charging, and battery is being used but going down.
Any other ideas as I’ve tried a new I/O Board and 2 new batteries now.
Thanks!
Questa è una buona domanda?
Punteggio 1
11 Commenti
Lets take a deep look here run this gem of an app CoconutBattery take a snapshot of the main window with the MagSafe charger connected and a second snapshot with it removed. Paste them here for us to see Aggiungere immagini ad una domanda
da
try a different dc in board
da
What’s that involve, is it doable myself?
da
the i/o board guide that trevor posted
da
Did you have a liquid spill at some point? I'm thinking the charging logic within the logic board is damaged.
da
Mostra altri 6 commenti
Aggiungi un commento
1 Risposta
Risposta Più Utile
Two possibilities:
Most likely possibility: bad battery
MacBook Air 11" Late 2010 Battery Replacement
MacBook Air 11" (Late 2010) Battery
Less likely possibility: I/O board
MacBook Air 11" Late 2010 I/O Board Replacement
MacBook Air 11" (Late 2010) I/O Board
Immagine Replace an I/O board compatible with the Late 2010 model MacBook Air 11 inch laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, USB, and audio ports.
Prodotto
$74.99
Immagine Replace the 4790 mAh battery compatible with MacBook Air 11" (2010). 35 Watt Hours (Wh), 7.3 Volts (V).
Prodotto
$79.99
Immagine MacBook Air 11" Late 2010 Battery
Guida
Difficoltà:
Moderato
15 minutes
Immagine MacBook Air 11" Late 2010 I/O Board
Guida
Difficoltà:
Moderato
Punteggio 1
Aggiungi la tua risposta
andy hawkins sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 253
