Samsung tv 56” much static at medium through high volume
The unit sound system, speekers has static noise which becomes louder as volume increases.
Questa è una buona domanda?
Punteggio
0
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 39
Hi @tank6 ,
Can you connect an audio amplifier with speakers to the TV's audio out stereo connectors on the back of the TV ?
If you go to Menu > sound > TV Speaker and select Off the TV speakers will be muted and the audio is available on the audio out sockets.
If you leave the TV Speaker setting On there should be audio on both the TV speakers and the external audio amp.
This is just to see (listen?) if the problem is with the TV speakers or the TV's audio system
da jayeff
