Salta al contenuto principale
How can I remove a stripped screw?
I was trying to remove the screw to get into the laptop and ended up stripping the screw. Any idea how I can take it out?? I've tried using superglue, didn’t work
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
you can make a small groove at one side like the photo
Punteggio 1
Here’s the iFixit Guide on stripped Screw Removal:
Come rimuovere una vite danneggiata
Punteggio 1
Their is a special bit/tool that can remove stripped screw heads but cannot recall it’s name!…This problem can occur when the wrong screw driver is used to remove Philips/ Pozidrive type drivers but especially when the tool is not a snug fit and plumb with respect to the screw.
Punteggio 0
Aggiungi la tua risposta
Sabeel Hussain sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 8
Tutti i Tempi: 829
