Salta al contenuto principale
Repair for speakers, stereos, header units, and CD players for your car or truck.
247 Domande Visualizza tutte
In car sound system button stuck on Volume Up
The device in question is a Sony sound system for my vehicle. Model: CDX-CA900.
I’m having trouble turning it on anymore. At first I thought that the Source button (turns it on, it only has a few buttons) might be faulty. So I troubleshooted and reset the whole thing, and even did a continuity test on the button. Seems to work, but when I force it to work by putting a CD in to turn the system on, the volume goes up to maximum. I had a moment to put two and two together, and decided to do another continuity test on the volume up button to find it is permanently stuck on. At this point I’m assuming that is the reason I can’t turn the system on.
Any suggestions for a fix?
I’m seriously considering just soldering off the button and using the remote(s) instead.
On the very right of the bottom part is the Off button.
Left middle button is Source. Top button is Volume Up. Bottom button is Volume Down.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
Here’s a link to the service manual which may be of some help.
Here’s the Sony part number for the switch 1-771-883-11 (see p.43)
A brief search online failed to find a supplier of the part. You may have better luck.
You could always check here and see if there is a compatible replacement available
In the end your idea is probably the quickest option.
Punteggio 3
3 Commenti:
Despite the effort, solutions like this is why I love to repair stuff.
da
Probably a discontinued part. Would consider substituting it, but not worth the effort. Appreciate the amount of detail provided though.
da
Wow...just noticed you hit 200K...Congrats!!!
da
Aggiungi la tua risposta
Jason sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,550
