Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
iSight rear camera blurry after replacement
I ordered a replacement rear iSight camera from iFixit as the previous one was causing the camera app to freeze. After replacing the camera everything now works as it should but the rear iSight camera is blurry, not crisp. Photos taken also are blurry.
Do yoy you think it’s something with the rear iSight camera itself or somehow it’s not seated properly?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I would pull the part again and use isopropyl alcohol and a q-tip on the inside of the glass and make sure the lens isn’t covered by a small piece of plastic.
Punteggio 1
2 Commenti:
I cleaned the inside of the glass with isopropyl alcohol and the q-tip and that addressed the issue. Thanks again.
da
No problem!!
da
Aggiungi la tua risposta
spearson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 746
