The body of the camera is getting sticky
Dear Sir
Iam noticing that body of my d70 nicon camera is getting sticky. What can Ido to solve this problem?
Hope that you find a solution.
Thanks
George Sciberras
Malta
Questa è una buona domanda?
Dear Sir
Thanks
George Sciberras
Malta
for the body of the camera you can use Edwal film cleaning solution or 91% Edwal film cleaning solution or my personal favorite, a 90+percent isopropyl solution (your local pharmacist would be of great help if you can't find it). Take a cloth and dip it in the solution and wring it out so that it is almost dry and wipe the body off. You can also use an old, soft toothbrush or small model brush dipped in the solution. Isopropyl alcohol works great to clean off cameras; any excess moisture that gets in the camera will evaporate quickly, and the alcohol works well to remove grime, grease, oil, etc. Hope this helps, good luck and may your camera soon sparkle again.
Thanks for your solution I hope that it works.
THANKS VERY MUCH
GEORGE SCIBERRAS
MALTA
you are very welcome and do not forget to post pictures from your location.....:-)
Thank you oldturkey03 for the advice! It worked real fine on my Nikon bodies. :-)
Isopropyl alcohol worked a treat. I then buffed the grips with a small amount of Armorall on a cloth for an as new look and feel. Thanks.
Natrual soft rubber will deagrade and return to its "Non-Vulcanised state". It is actually slowly "un vulcanising". Molecule cross links breaking back apart that were joined in the rubber vulcanising process, and becoming liquid in state. Handling or sitting, you can not stop natural soft rubber from "going back home".
The top surface is effected 1st which then deepens and deepens until you could wipe the entire rubber off with cloth after 25 years. More rigid high vulcaising rubber will powderise back to dust. (like 50 year old tyres)
Using alchohol will merely disolve and strip the top liquid rubber layer off, back to the "still rigid" rubber underlayer. You'll need to do it again in a few years.
Following the advices here, I rubbed my old F80 and D70 bodies with pure Isopropyl alcohol (99.8%) and a lint free cloth, and both recovered the original grip and look. It's a job that one has to do with plenty of time and detail to get a perfect finish, but it's worth the effort. I have a AF-S DX 18-70mm zoom that needs the same treatment on the focus grip. Just be careful to do it in a well vented room (Isopropyl alcohol is harmful if breathed). Thanks a lot for your help!
could you use the isopropyl alcohol outside? As you said a well vented room.
I have a Nikon D70s with a very sticky body. I rubbed 91% Isopropyl Alcohol on the entire body about 6 times which finally eliminated the stickiness but it dulled the finish. I then used several ArmorAll clean wipes to coat the finish and restore the sheen. I may have to do it every few years but it's well worth the effort.
I pulled the camera out today and found that there are no sticky parts on the body 3 1/2 years later. Bottom line, Isoproply Alcohol and ArmorAll wipes really works.
Six years later and there is still no stickiness on the body. It appears the Isoproply Alcohol and ArmorAll wipes permanently solved the problem.
Again I pulled the camera out for a day of shooting and still no stickiness. Using Isopropyl Alcohol really does permanently solve the problem. BTW, early model Nikon DSLRs like the D70, D70s, D80, D90 and D40x are super cheap today and are still fun to shoot with.
Alcohol removed the rubber coating on the plastic body. You now have a plastic finished D 70
@om1gc - The camera body looks and feels exactly as it did when it was new. No plastic showing through.
Same problem with D70. The secret with the isopropyl is a gentle wipe. Don't try to rub it dry as I did the first time. Allow each cleaning session to become well and truly dry so that the 'plastic/rubber' becomes firm again. As with Ken above, patience is required . 4 or 5 'sessions' and it's fine now.
Martin G
Alcohol just makes it stickier and then the black comes off on your hands...any other suggestions?
You want it to go into a [preferably white] lint-free lens wipe. If it is going into your hands it is probably not low moisture alcohol or Isopropyl. Ask pharmacist for "absolute". Mine looked more yellow than black - you must be pulling out the carbon black which is not good.
I dried it up with baby powder. Worked it into the areas most gummy by hand and used a compressed air can to blow off excess. Gently wiped area with microfiber towel and the tacky is gone...for now. I know it's a chemical break down and will continue but for now at least it's usable...
You need to keep at it 4 to 6 times with a strong cloth or wipe. The cloth will collect the goo then toss away.
Microfiber cloth + >60% ethyl alcohol (hi octane hand sanitizer works)+ elbow grease = success
Coat it over with a thin film of lacquer or transparent nail polish. It will stabilize the rubber.
Rubber will deteriorate in time - and the later Nikon models are notorious for this.
Reading all these posts today, and owning a sticky F70, here is my advice:
STEP 1
>90% alcohol will remove the sticky rubber - if rubbed away with a lint-free cloth. Do this for a thin layer once a day and let the alcohol evaporate before repeating. If after 5 goes at this it is still sticky, then move to step 2 below:
STEP 2
Nikon F70s had only a thin rubber layer on top of a polycarbonate camera body. If the rubber has deteriorated to full thickness then it will come off the plastic as a sticky, tarry mess. that will never improve however many layers you polish away. The only solution then is to either
[1] rub talcum powder into it to reduce the stickiness as a temporary fix - but it always returns worse than before with a black “porridge” on your fingers!
[2] carry on a rub it all off (with ear buds, tooth brushes etc to get the remaining rubber off around buttons etc, This leaves a shiny plastic camera that is slippy to the hands. Consider adding a strip of tape, or leather or rubber to the hand grip area to restore finger friction and prevent drops.
Best of luck to you all - PaulC
That's not my experience on my D70s. See my comments above. Seven years later and my D70s is still free of stickiness.
Hi Ken - Nikon F70s had very thin rubber layers of <0.5mm coated like paint onto a poycarbonate body panel while digital Nikons (like the D70) had very thick rubber skins of several mm thickness over a metal chassis.
My D50, 80 & 200's all have very thick rubber which fix obligingly with isopropyl alcohol.
The most common causes of rubber deterioration are exposure to light, oxygen (ozone) and heat - and sometimes to chemicals in cleaning materials we use (or "misuse"!) on our camera bodies. This explains why cameras used and stored in different conditions decay at different rates.
Glad to see your D70 is still going strong - those models must now be 20y old, but their CCD sensors are now coming back into photographic fashion!
Best wishes - Paul
You can also get replacement grips and body covering on Ebay.
WOW! not an easy task! Nikon D70 Grip Replacement Grip removal for D70. OEM replacements for $39. The cleaning leaves the semi texture so it will still work OK
You may have experienced Plastic, that has become Sticky?
Some time ago, there was an article suggesting that you could use Acetone?
But was not sure of its use, on all Plastic types, then came across This Article:-
https://heartworkorg.com/2017/01/08/stic...
and it Does work; Found that you need to rub a Slurry Mix over the surface, then lightly
wipe off, with a wet, (Soft, 3M type) Pan Scourer.
I then wiped the surface with some Washing Up Liquid, wiped with a Damp cloth, then Dried.
I have both a Nikon N80 and D80. The N80 body is sticky like all the notes I’ve been reading. I used some baby powder which stopped the stickiness but it does look very presentable. Obviously the N80 isn’t worth much anyway so I’m not losing any sleep over this odd development. The D80 body doesn’t have a problem - so far.
It is irresponsible for Nikon to sell products with this kind of problem. When I called them about my Coolpix S8100, I was told that they don't know abut the problem. And since the camera is out of warranty nothing they would do!!! Shame on you Nikon.
The 5400 had a rubber glued on grip.. but the glue failed and the rubber stretched so it could not be reattached. This spray on rubber was to be more durable but as other items had the same problem. It becomes a problem if there are labels place on it which will be removed.
Hi its a problem often with modern cameras. What always works for me is : soft cloth and dab all over…dont rub, you may want to do it twice .. with Isocol, its a rubbing alcohol antiseptic available from the chemist.
Allow this to set dry a few hours of the next day. Then use a liquid car wax to seal it. and there you go better than new .. Make sure the liquid wax is NOT one that dries white,…….. that is a big nuisance.
In France we have alcool ménager (household alcohol) that is used as a general purpose cleaner/degreaser.
Worked perfectly on the rubber parts of an old Microsoft webcam. Just wiped it with a few drops on a paper kitchen towel. The stickiness was only superficial and there was hard rubber underneath. My guess is that any alcohol would do - gin, vodka, anything you have to hand.
I am pretty sure that you can use a cotton swab, if the sticky dust is not removed with a brush and of course if you need to clean hard-to-reach spots, a rubber bulb is pretty effective.
All this "solutions" are not for any camera bodies. My Minolta Cannon and more, have this problem, but nothing can be done, the rubber layer of it has oxidized. And it is impossible to clean this or remove the layer. Just designers did not take in account these consequences of having the camera for 40 years.
Glad you didn't mention Nikon because I know for a fact, based on first hand experience, that 92% (or greater percentage) Isopropyl Alcohol removes stickiness on older Nikon DSLRs. I used it on my Nikon D70s over 6 years ago and still no stickiness.
The part that is sticky is the soft rubber coating over the plastic.. There is hard plastic underneath and when the sticky part is removed you will have a hard plastic that last for a long time as is if you do not use harsh chemicals. Nikon N80 and D70 have cleaned up well and are still fine after 10 years.
For those who clean their Nikon cameras, The D70 can look shiny if all the rubber is removed. Grip side has more decay and now is down to the base plastic.
The left side has less decay and some rubber material remains
Both sides are now not sticky. The grip is still OK to use but you may want a strap There is no removable rubber cover to replace, once decayed it will rub off.
Ultime 24 Ore: 13
Ultimi 7 Giorni: 47
Ultimi 30 Giorni: 210
Tutti i Tempi: 133,070
19 Commenti
sticky as in when you touch the camera, or sticky as in the components of the camera are getting stuck?
da pollytintop
will this work on the gopro 1 body?
da drcbetr
Will this work on fujifilm finepix HS50 EXR????
da Kanishka Rao
If company's now know about this why do they still use the process of coating hardware products with it. Cameras such as Canon and Nikon make expensive high end products and to have this coating breaking down either the camera or the lense ruins the product. As an e.g. I have a mobile phone from 1993 and the keypad on that too has finaly gone sticky. I can't clean it as the numbers are transfers put directly on to the coating which will ruin the keypad if cleaned. Concidering the age I'm supprised it had not broke down before now. Most modern products do farley quickly.
da thgun
Have you handled the camera after using DEET bug spray? This is a known culprit for "melting" the material on some plastic-based camera bodies. Ask me how I figured it out: On assignment photographing bird tagging in the woods and spray myself with DEET first. I posted this on the internet as much as possible as a warning for other photographers.
da Peggy Stevinson Bair
Mostra altri 14 commenti
