Salta al contenuto principale
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 Domande Visualizza tutte
Does the MacBook Air have a PRAM Battery?
When I first bought my MacBook Air, the battery was completely dead. I used CoconutBattery and determined that it needed to be replaced. The time would always be set back to December 31, 2017 at exactly 7pm. With the new non-apple battery assembled in June of 2018, the MacBook Air would shutdown after a bit and the time would get reset to the mentioned time again. I launched CoconutBattery and it states it’s been through only 1 load cycle, despite the fact i’ve charged the battery several times now. I performed an SMC and PRAM reset with no luck. Battery is compatible with this specific MacBook Air model, as i have checked with the description and the seller.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
There is no PRAM battery in this series.
The LiOn battery has a special tap to supply a trickle voltage to hold the settings.
Where did you get the battery?
Punteggio 2
5 Commenti:
I kinda thought it wouldn’t have a PRAM battery, thanks for clarifying. Here is a link to the exact battery I got:
https://www.amazon.com/AY-A1496-High-Per...
da
You'll need to get a replacement from them.
da
I don't suggest buying batteries from an unknown company on Amazon.
da
After having the MacBook Air shutdown while plugged into the outlet, I'm starting to assume it's more than just a battery issue. Could there be a possible board fault?
da
Why don't you give CoconutBattery a try to see what it tells you. Post a snapshot one with the MagSafe connected and one not so we can see whats happening here Aggiungere immagini ad una domanda
da
Aggiungi la tua risposta
Damien Gordon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 39
Tutti i Tempi: 3,157
