Salta al contenuto principale
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Domande Visualizza tutte
IR sensor connector broken, need to identify power connector
In the process of changing the speakers, the IR sensor connector broke off and all the wires are black instead of having any kind of color coding. I need help to identify the power and GND connections on the logic board so I can solder the wires instead or attach them with tape of something.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Did you damage the logic board or the sensor side? If you damaged the sensor cable side I would just replace it as its quite easy to do Infrared Board w/cable - Apple P/N 923-0251
If on the other hand you damaged the logic board connector
Then you’ll need to replace the connector. How about pasting a clear set of pictures of the logic board area and the connector part so we can see whats damaged Aggiungere immagini ad una domanda
Punteggio 2
Aggiungi la tua risposta
Einstein sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 439
