Salta al contenuto principale
Il tablet Surface Pro di quarta generazione, lanciato sul mercato il 26 ottobre 2015.
208 Domande Visualizza tutte
Is there any possibility that a Surface 4 has Surface 5 LCD?
I have Surface Pro 4 (This is the gift I have received) I dropped it and broke the LCD.
I bought an LCD, for Surface Pro 4, to repair it, from eBay. I removed the broken LCD, but the new one did not match the original cable.
I searched for letters written on genuine LCD, the letters is LP123WQ1. When I searched I got it was for Surface Pro 5, 1796.
I don’t understand, because mine is written 1724, behind the back.
What should I do?
Why is there another version of LCD on my Surface Pro 4?
Can I fix it with LCD, bought eBay?
Questa è una buona domanda?
Punteggio 2
3 Commenti
Can you post a set of pics one of your Surface Pro 4 an the Surface Pro 5 cable connections so we can see the differences.
da
I may have a similar problem! I have a surface pro 4 that was ordered on amazon. I have ordered a new lcd and digitizer and all matches but the cable connectors :( I have pictures but am not sure how to post them here.
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
Here are the pictures of the differences on my old surface pro 4 and the new lcd that was ordered for the surface pro 4
Punteggio 1
hi sorry its late but there are 2 version of lcd’s on the pro 4. one is made by lg and has a fatter cable that resembles a pro 5 lcd flex and the other which is more common has the standard looking pro 4 lcd flex.
Punteggio 1
Might be a little late to the party, but yes this is a very real possibility. My Surface Pro 4 screen cracked and I ordered a replacement on Amazon. The screen I got had a fault so the seller send me a Pro 5 screen with an adapter cable. So yes, my surface Pro 4 has a Pro 5 screen with the corresponding adapter cable
Punteggio 0
I realize this is an old thread but it's unanswered. The surface pro 4 uses the same screen as the surface pro 5 and 6 The cables are technically the same cable just a different shape. To use the surface pro 5 screen on a surface pro 4 you just need to get one of the new cables.
Punteggio 0
Aggiungi la tua risposta
min le sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,045
