Salta al contenuto principale
7.1 megapixel camera by Canon, model SD750.
How do I adjust autofocus?
The camera works except pictures are always out of focus. Is there a way to make an adjustment?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Want to rule out the possibility that basics needed we being done.
1. Press and hold the shutter button halfway for about a second or two before pressing completely. When the camera focuses, the camera will beep twice and a green indicator lights on. Also a green box appears on the LCD of the camera. Please let me know if this works.
Punteggio 2
3 Commenti:
Refer to this for more information
http://gdlp01.c-wss.com/gds/6/0900001456...
da
Thanks but I do know about holding the shutter button. The picture is visibly out of focus even on the LCD screen.
Any Ideas?
da
have you tried taking the camera apart and cleaning it/blowing air around the lens? It may be something is blocking the barrel from fine focus. other than that I'd imagine this may be a problem with your zoom/focus flex. if you follow the guides on the right there are a few links on the first page to parts shops and a blog about a lens problem..she has taken parts from a different powershot..it's worth a read and may help you a bit more..
btw are the photos on your pc out of focus or just on the lcd??
da
Aggiungi la tua risposta
Peter Tropper sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,444
