Salta al contenuto principale
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 Domande Visualizza tutte
Having disconnected the battery, wich charger to use to try to boost
Good morning,
My MacBook A1534 (year : 2015) has suffered liquide damages and the « power » button does not work anymore. Do I have to connect the USB Charger 12 Volts or do I have to use an Iphone Charger via USB in order to try to boost, having disconnected the battery, I want to determine whether it is the keyboard or the Logic Board that is not functionning.
thank you in advance
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Use a 5v. charger with 2A power to be on the safe side, one such as those for iPad would do. If the logic board isn’t damaged it will show signs of life as soon as you plug it in.
Connettere a bassa tensione dopo ogni riparazione (solo MacBook Retina 2015)
Punteggio 2
2 Commenti:
Thank you very much for your answer. Do we have also to unplug the keyboard ?
da
@paprika Not necessarily, but if liquids entered via the keyboard and/or you suspect it got damaged it would be a good idea as a shorted keyboard or trackpad might prevent booting and proper functioning.
da
Aggiungi la tua risposta
C.G sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 61
