Salta al contenuto principale
Il modello Huawei al top della gamma 2017, lanciato nel marzo dello stesso anno. Caratterizzato da un corpo unibody e da un sistema con doppia fotocamera posteriore sviluppato in collaborazione con Leica. A scelta con memoria interna da 32 o 64 GB e sei differenti tipi di finitura. Numeri modello VTR-L09, VTR-L29, VTR-AL00, VTR-TL00.
Water Damage and still wont load
Hey all my first post :D now i love dealing with pain phones so i took this one on a Huaweii P10. All ive been told is it got wet it worked for a while and then it turned off. What ive done so far :-
Cleaned board with 90% alcohol stuff, that solution that Ifixit recomeneds
New Battery
New Charging Baord
New Main Flex
New Screen
When i plug the charger in all that happens is the red light on the screen flashes, it does this with the battery plugged in and out also when i press Power Up + Power i get the flashing light but i press just power i get nothing. When i got the phone it had enough power to cycle vibrate as it trys to turn on so its got to be the battery not charging.
Any body have any words of wisdom for me to try or does this need to go to someone with a sonic bath :)
Many Thanks
Simon
Questa è una buona domanda?
Punteggio 2
3 Commenti
Did it show signs of corrosion before you cleaned it. There's possibly a short which is why it won't turn on
da
yeah there was corriosion but i cleaned it all, only part i cant get to is under the shields but still im getting the flashing red light nothing else. Guess this one is a loss.
da
I decided to clean the board one more time last night :) dried it off with nt heat gun on low settings and left all night. Hooked it all to this morning and put it on charge now the red has gone and been replaced with a solid white light that turns off when I hold the power button
da
Aggiungi un commento
1 Risposta
Risposta più utile
Hi @simong93 ,
Usually under the shields is where the problems are because the water gets trapped there and takes longer to evaporate which doesn't help if the power is reconnected before it has or stop the corrosion once it has evaporated.
The only chance, slim that it is, is to remove the shields and clean it and hope that it might work
You could try and use an ultrasonic bath to try and clean it but again I think that the damage is already done and it is too late.
Punteggio 1
2 Commenti:
da
Hi @simong93 ,
If you didn't remove the shields, that still leaves the corrosion which will come back to haunt you sometime in the future.
Drying out a device doesn't remove the corrosion which in itself can provide a conductive path (resistive admittedly), which shouldn't be there in a circuit.
You really have to clean it all away thoroughly to ensure that there are no problems.
da
Aggiungi la tua risposta
Simon Gilbert sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 22
Tutti i Tempi: 1,126
