Salta al contenuto principale
Lanciato nell'aprile 2010 / processore Core i5 2,4 o 2,53 GHz o Core i7 2,66 GHz
590 Domande Visualizza tutte
Can I "upgrade" my main logic board?
Is it possible to replace the logic board in my mid 2010 MBP with a later model? If so, what would be compatible. While browsing the parts section I see that up to mid 2012 the main hardware and ports (number and type) appear to be identical. I ask this because 1) if it is possible, it’s cheaper than a new MBP equivalent, 2) I like the fact that this model has a built in SD card reader and Superdrive and 3) I can’t upgrade to Mojave.
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Actually, you can upgrade to Mojave using Dosdude1’s Mojave Patch Tool. It’s not that hard either.
http://dosdude1.com/mojave/
Update (11/06/2018)
Come installare macOS Mojave su Mac non supportati
Punteggio 0
2 Commenti:
Hah, yes! That would be much preferred! Since I already have an i7 2.66GHz and am installing a 500GB SSD and 8GB RAM, there's little need to change the logic board. Thanks!
da
@kct78952 No problem! DosDude1 is a life saver when it comes to older Macs becoming obsolete. Happy I could help. :-)
da
I think you’re better off just picking up a used 2012 model Vs spending all of the effort to make this work.
As for changing things about you’ll also need a new display as Apple changed the LVDS connection between these modes enough that you need that too.
Punteggio 0
Aggiungi la tua risposta
KenT sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 41
