Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2692 Domande Visualizza tutte
Phone is charging turns on its 1% then turns off and repeats
so my iphone 6s is charging its keeps turning on and is on 1% then shows passcode then turns off and turns on again its keeps staying at 1% please help me asap
Questa è una buona domanda?
Punteggio 1
1 Commento
Do you have a computer running macOS handy?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
It is likely that the battery has reach the end of its life cycle and will need replacing. That is the cheapest repair to try first. If that doesn’t solve the issue, then the next likely cause is either software corruption or Tristar chip on the logic board needs replacing. This is all assuming that the phone hasn’t had severe external or liquid damage. Hope this helps.
Punteggio 1
Check: Settings-Battery-Battery health. If it’s below 90% (my 6s was at 88%) you may be able to get a free battery replacement from Apple. I did mine a few months ago and it’s like having a new phone.
Check this site: https://www.apple.com/support/iphone6s-u...
Punteggio 0
Aggiungi la tua risposta
Blade sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 49
Tutti i Tempi: 521
