MBP Retina 2014 CPU overheating due to temp sensor bug
So in this client’s MBP CPU apparently has a bug in temp sensor which leads to incorrect temperature reporting and overheating leading to kernel panic eventually.
While in OS it can be alleviated by tool like SMCFanControl by just ramping up fan speed regardless of reported temps but it is not working during preboot such as system updates leading to overheating and KP because fans are spinning too low(since SMC getting wrong temp) for generated heat. And KP during updates means hello to system reinstall (which by itself can only be successfully done if room ambient temperature is around zero in Celsius). Which is no fun.
So I am thinking about cheap & cheerful way of going around problem since replacing CPU is not very cheap in my book.
What do you guys know about manual changing fan speed due to resistance on some of fan lines? What are on fan connector pins in this MBP? Could it be that adding simple hardware switch like shorting one pin to ground will put fan in full blast? If that can be done so that would be just enough for the moment of installing system update and anything else can be fixed on OS level.
Any ideas appreciated!
Questa è una buona domanda?
1 Commento
Lets get a better idea on whats happening here. Disable SMCFanControl and instead install this app: TG Pro. Post a snapshot of the main window (you may need to resize the bottom so we can see all of the sensors) Aggiungere immagini ad una domanda
da Dan
