Salta al contenuto principale
From the Inspiron series 15 model 5558 released in 2015 by Dell. A mid-level laptop with a 15.6-inch display and fifth generation Intel processor.
16 Domande Visualizza tutte
My Dell Inspiron 15-5558 will not turn on.
I did not use my laptop for a day or two and it won’t turn on. The light that lights up when charging or on did not turn on and I did not hear the fan. I also tried charging it and nothing happened. I tried troubleshooting according to Dell’s instructions but it didn’t turn on afterwards. Is there anything I can do?
thanks!
Questa è una buona domanda?
Punteggio 1
1 Commento
I'm having the same issue. Did you ever figure out what was wrong with the laptop?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @kmh17 ,
Was the laptop dropped or did it get wet at all?
If not, try a power refresh and check if this resolves the problem.
Switch off and disconnect the charger from the laptop (if connected).
Remove the battery from the laptop (here’s how Dell Inspiron 15-5558 Battery Replacement)
Press and hold the laptop’s Power button for 30 seconds and then release it
Reinsert the battery
Reconnect the charger to the laptop and switch on the charger.
Turn on the laptop in the normal manner and see if it starts OK.
Punteggio 2
1 Commento:
While I do not believe water got on it or that it was dropped, it could have happened without me remembering that it did. Unfortunately, the power reset did not help.thank you for your suggestion though!
da
Aggiungi la tua risposta
Bad with tech sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,980
