Is my TV lcd panel causing T-con failure?
Hi Guys,
I had a vertical red line on the screen of my 55” Samsung Led tv. After reading on internet, I tried to open the tv and press the cable ribbons on lcd panel which are attached to screen. It did not work and I could not find any bad connection.
Then I disconnected the lcd panel from T con board and re-connect it while tv was still ON and BOOMMM, everything went to dark. No display at all and just a black screen.
Now is it possible to damage T con board this way or I have just damaged the screen panel?
Also there were two conductive tapes between Lcd panels (one on left and one on right panel) and TV body. Is it important to have those tape connected to the body of the TV? And if it is the case then how do I find the place where this tape should be connected between tv body and lcd panel? I removed the tape in order to take the panel out.
I have ordered the T con board assuming that this might be the damaged part. Any help or comments will be appreciated.
Thank you.
SAM
Questa è una buona domanda?
