Salta al contenuto principale
L'aggiornamento di marzo 2015 del MacBook Air 13" di Apple ha processori di quinta generazione Intel Core i5 e i7, risultando in una migliore performance e maggiore vita della batteria.
623 Domande Visualizza tutte
Mac internal disk cant have mac os installed on it
About a year ago i erased my Mac and installed Windows on it, so that there is no MacOS partition, only Windows.
Now i want to go back to MacOS, so I went into recovery mode, only it displayed the 2003F error. I then made a bootable installer on a 8 GB USB, and then went into Disk Utility from there.
I tried to erase the internal drive so I could install Mojave on it. It displayed the error “Erase process had failed. Click Done to Continue”. I erased it with the name “Macintosh HD” and in the MacOS extended (journaled) format. Then it would not mount, so I tried running First Aid, and it instantly said “First Aid process has failed. If possible back up the data on this volume. Click Done to continue.
I’m going to try installing MacOS on an external hard drive and then restoring the disk from that.
If that doesnt work, why is it doing that and how do i fix this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I think you are at a dead end here ;-{
From what you’ve stated the drive has failed and will need to be replaced. The failure of Disk Utility tells me that.
Depending on what you are planning on using your system for it might be a great time to upgrade the drive to something larger. Here’s a good reference: The Ultimate Guide to Apple’s Proprietary SSDs and here’s the IFIXIT guide: Sostituzione SSD MacBook Air 13" versione inizio 2015 and here’s one other option using a 3rd party drive [prodotto collegato mancante o disabilitato: IF123-123]
Punteggio 2
Aggiungi la tua risposta
Kevin Xu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 184
