Salta al contenuto principale
The LG X Power is a 4G LTE smart phone that was released on August 2016. This model has a 16 GB memory with an Android operating system.
phone is very hot
I have a lg-x230yk
1 month old it does not stay charged and gets very hot
I only have emails and face book apps
wifi and blue tooth is off
im new to phones
thanks julie
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Depending on carrier usually in Sprint zone or my Verizon there is a support section which you can run a diagnostics on the battery life/usage. That will show what is using the most battery charge.
Now for the phone getting warm. LG’s (I’ve had the G5, X, and now the G7) all of them have had a horrible issue with heat dissipation.
some things to take into account, do you have mobile data enabled? If the phone is constantly switching between 4G/3G/1X then this would account for the heat & battery drain. or are you possibly in a weak cellular signal area? If it's constantly trying to find a signal then the same thing could happen.
A way to test (which can be a nuisance since we usually need our phone) is charge it up and place it into airplane mode. If it continues to overheat and drain battery there. If the issue goes away then it is definitely one of the issues with data/signal. If not I would look at replacing battery. As for the heat… there may be a couple applications that assist in identify battery life issues but I hope we don’t have to get to that point.
Punteggio 1
Aggiungi la tua risposta
julieblue2011 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 156
