Salta al contenuto principale
Processore quad core Intel Core i7 da 2,4, 2,7 o 2,8 GHz (3,8 GHz con Turbo Boost) con 6 MB di cache L3.
263 Domande Visualizza tutte
Which wifi card to upgrade to? Latest card that fits 2013 MacBook Pro
Would the wifi card model BCM94360CS fit the early 2013 macbook pro retina 15” ?
I want to upgrade my old wifi card that doesn’t support 802.11 ac and was wondering which is the latest model that supports it ? I am guessing the newer touchbar based macbooks have a different card ? would any of those cards support the early 2013 macbook pro ?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The newer MacBook Pro touch bar as well as the function key models all use chips which are soldered to the logic board unlike your MacBook Pro system which uses an AirPort board MacBook Pro 13" and 15" Retina (Late 2012-Early 2013) Airport/Bluetooth Board. The best you can go with is MacBook Pro Retina (2015) Airport/Bluetooth Board
Immagine MacBook Pro 13" and 15" Retina (Late 2012-Early 2013) Airport/Bluetooth Board
Prodotto
$49.99
Immagine MacBook Pro Retina (2015) Airport/Bluetooth Board
Prodotto
$24.99
Punteggio 3
2 Commenti:
I have upgraded my 2012 MBP’s AirPort Card from 2012 to a 2015 Card. I have gig speed internet and it gets more MBPS then it’s original card. Definitely worth an upgrade if you have speedy internet.
da
Just did this upgrade, my download speed has 111Mbps before and now is 221Mbps. I have 300Mbps connection, but this was an amazing upgrade. Installed, didn't need to configure anything at all. Airdrop worked right away. Thank you danj.
da
Aggiungi la tua risposta
scorpion789 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 118
Tutti i Tempi: 6,637
