Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
iPhone not charging and 0 Amps
Hi, I received an iPhone 6S from a customer that said that their screen and battery need replacing. I replaced both of those but when you turn the phone on it boot loops. I plugged it into a USB ammeter and I’m getting 5V and 0.25 amps being drawn when not turned on which looks like it’s charging the battery but when you turn it on it boots but doesn’t charge. It drops to 0 amps when booting and the CPU area gets slightly hot but stops when booted. When not plugged into a charging cable and boot looping the CPU area gets really hot.
Would appreciate the help Thanks
@refectio
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Do you know the history of the device? If it was dropped, repaired, came into contact with water or if the customer was using cheap chargers, then that would help you in your troubleshooting.
I agree with A1, try isolating the logic board with a known-good battery and Lightning Port. If it still doesn’t boot, then you definitely have a board level issue. Depending on the history, you could focus on the charge circuit, or probe the PMIC/BBPMU and main voltage rails for additional clues.
Punteggio 2
1 Commento:
I have done some further tests and have managed to boot the phone on a good known battery however the phone doesn't charge at all. When plugged into a charger it doesn't charge the battery and it keeps on dropping at a normal pace. I have ordered a new charging flex and the history of the phone is not known but it looks like the phone was dropped heavily on the front looking at the cracks on the screen. Thanks for the help
da
Risposta Più Utile
I would start with doing an isolation test disconnecting cameras and flexes.
If issue is still there I would say Tristar could be the cause.
Punteggio 2
Aggiungi la tua risposta
Tom sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,425
