Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
Bottom microphone not working
So I brought my iphone to authorized repair center to have my lightning port + headphone jack assembly replaced. after a while I noticed that whenever I receive a call the person on another end can’t hear me so I tried voice memo and it won’t pick up any noise unless I shout closely to the bottom of the phone. front facing and back microphone are working fine when I am making video.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sounds like the microphone that the “authorized repair center” installed has failed already. They probably used cheap parts and/or did a sloppy job installing the assembly which resulted in damage to the assembly.
You can replace the assembly with a more quality part at the link below. I also included a guide for you just in case you wanted to DIY.
iPhone 6s Plus Lightning Connector and Headphone Jack
Connettore Lightning e jack cuffie iPhone 6s Plus
Immagine Replace a battery compatible with iPhone 6s Plus Models A1634, A1687, A1690, and A1699 smartphones. Part #821-00126-A.
Prodotto
$24.99
Punteggio 1
Aggiungi la tua risposta
ronnel jay banay sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,227
