iPhone 7 battery drain, discharge.
Hello.
First - thank you for this comunity, forum and all the answers here. Been really helpful.
But it’s time for my firs question.
I have second hand iphone 7 with battery that had close to 1000 cycles, and charging port that sometimes lost connection if the cable was moved. Replaced the battery and charging port. Abviously had really bad battery life and was discharging fast.
But all 3 new batteries (non-original) i tried shows “service“. As i read it just happens.
The phone carges ok, boots ok,connects to computer, draws current ok (as far as i can tell without testing it with multimeter on the board) but still discharges quite fast. 2x-3x times faster than normal iphone 7. Tried disconnecting all parts but the result is the same. If the screen is disconnected it seems to discharge even a little faster.
From what i have read it seems that it could be te u2ic tristar fault.
Phone has been updates, restored and reset.
Could it be anything else?
Are there any other ways to check it?
As the local options to replace professionally is around 100 euros without warranty.
Questa è una buona domanda?
