Salta al contenuto principale
Computer desktop all-in-one prodotti da Apple. Gli iMac sono stati dotati di processori Intel dal 2006 al 2021.
7455 Domande Visualizza tutte
Mxm connector have a weird solder joint (pic inside)
Picture of what i think is a weird solder joint on mxm slot imac 24" http://twitpic.com/4v1e5i http://twitpic.com/4v1e6o
What do you guys say? Should it look like this?
The thing is that my 8800GS fried and my newly bought 2600 pro also kind of fried ( could be due to bad thermal paste from factory as well ).
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
That's definently not normal. It might be why your cards fried. (Or they just aren't working because of the slot) Did the cards work for a period of time, or did they not work at all? You might be able to remove that with a fine-tipped soldering iron, or you may be able to scrape it off with an exacto knife.
Punteggio 1
2 Commenti:
Don't use an exacto knife you can cut the traces to the pins. Clean it before using a solder iron. Don't use a solder iron to clean with out flux.
da
Hi guys, long time..
I bought a new iMac 21.5" and the old one is just collection dust :(.
I am thinking about change the mxm connector or just try to fit an old laptop mother board. Does any one know where to find a spare mxm connector?
da
Aggiungi la tua risposta
Billyohgren sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,251
