Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
774 Domande Visualizza tutte
[EN/FR] Keyboard not working / Touche de clavier non fonctionnelle
Hi, my R on my keyboard is not working anymore. Is it possible to acces under the keyboard to clean it ?
Bonjour, ma touche R de clavier ne fonctionne plus, on dirai que quelque chose est coincé dessous. Est-il possible d’accéder sous le clavier pour le nettoyer ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@danj I've seen your answer concerning the z Key ("z" Key not working, Command key also) would you say the procedure is the same here or do you know if there's an option to get below the keys?
Punteggio 1
1 Commento:
Hi Sandra! - Sadly, it's the same! Only difference will likely be the keyboard mapping if Sunny is using a French keyboard.
Sunny - You maybe able to get this fixed under warranty if you bought it less than two years as the EU warranty is two years.
Do keep in mind any liquid spill will void the warranty.
da
Thanks for your answer !
Punteggio 0
Aggiungi la tua risposta
Sunny sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 234
