Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
Domanda Chiusa
Is the gps antenna my problem?
I am using an iphone 3gs 4.2.1 firmware 5.15.04 baseband. My gps doesn't find my location, it usually finds me about a 1/2 mile from my current location. My compass works fine and the gps works when I am on wifi so I am assuming it is a gps antenna problem. If I am correct is that the only thing I need to replace/check or are there other issues? I appolize if there is an answer already on here but i've searched to no avail. Any help would be greatly appreciated.
Questa è una buona domanda?
Punteggio 0
1 Commento:
is your phone jailbroken? there are some issues with a jb on 6.15.00 but I don't know of any on this one. you could try resetting network settings under settings/general-reset.
da
Aggiungi un commento
1 Risposta
It is jailbroken. It just started happening one day after I was on 3.1.3 firmware for like 8 months. I tried resetting everything, resetting network settings, back to factory settings, put apples 4.2 firmware and then a jailbroken 4.2.1 and nothing worked. I think the only option left is the gps antenna, unless I'm missing something.
Punteggio 0
1 Commento:
have you checked connector 6 (or it could be 5 i get them mixed up every time!) it's the single round pin connector. check it is on properly on the motherboard..sometimes after a drop it comes off partially.
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,301
