Salta al contenuto principale
Guide e supporto per varie marche e tipologie di televisioni (TV).
9064 Domande Visualizza tutte
Toshiba 49l310u Backlight blinks fast on Startup.
My Toshiba Tv Blinks On Startup, I Replaced the PSU/Backlight inverter Still Blinks the backlight on startup. I tried to set the backlight to 50 because it was 0 still did not do any thing.i used a flashlight to see what was on the screen.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Pasta YT  you will have to measure tehe voltage from the power board to the LED’s and check to make sure that your mainboard enables the backlight. Flashing backlight is most common with failed backlight strips.
Punteggio 2
Did you have to get a new tv?
Punteggio 0
Aggiungi la tua risposta
Pasta YT sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 454
