Salta al contenuto principale
Una console di gioco per la televisione prodotta da Sony Computer Entertainment, conosciuta anche come PS4. Annunciata il 20 febbraio 2013 e lanciata sul mercato il 15 novembre 2013.
1697 Domande Visualizza tutte
Issues with optical drive
I was cleaning my brother’s playstation 4 because the fan was overworked and the console was hot. When I opened it I left the game disk inside the drive and went on carefully disconnecting all cables and cleaned the system and it’s hardware. After I had put the console back together it still ran extremely hot but the fan still worked. The disk drive on the other hand stopped working entirely. It will take in a disk, making some sound like it was loading or even grinding for second then not recognize the disk. It will eject the disk and upon opening the drive itself there was nothing foreign inside and the disk was centered correctly. I cleaned the lens and still no luck. All cables and connections are correct and connected properly. There was no physical damage to any cable or the drive. I just dry wiped it. Also he has issues with his wifi as he gets about 20-30mbps slower than what I get on my xbox one even when they are next to each other and wired.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You may want to try a new optical drive. iFixit sells an optical drive for this console and also provides a part. You can return the optical drive and get a full refund if we determine it is not the optical drive.
PlayStation 4 SAA-001 Motherboard & Paired Optical Drive
Sostituzione del lettore ottico nella PlayStation 4
Immagine PlayStation 4 SAA-001 Motherboard & Paired Optical Drive
Prodotto
$168.99
Punteggio 0
2 Commenti:
The model of the ps4 is 1215a would there happen to be one for that?
da
@jonathanmnicoli The one I provided should work. If it does not you can return it.
da
Aggiungi la tua risposta
Jonathan Nicoli sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 34
