Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
iPhone SE battery drain and hot display connectors
Hello,
A few weeks ago, my iPhone SE randomly started becoming hot, and the battery drained really quickly (3hrs) I replaced the screen, battery and proximity sensor as well as cleaning the logic board but it still gets warm and overheats near the display connectors for no apparent reason.
Any ideas? The pins don’t look damaged.
Edit: It looks like more heat than usual is also coming out the CPU, I have tried a full reset and still no results
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I would start by testing a bare-bones setup. Start by disconnecting the battery first (always!). Then disconnect the digitizer, LCD, front camera, rear camera and home button extension flex. Now re-connect the battery; you should only have the battery and Lightning Dock flex connected. Connect a known-good, preferably Apple-original Lightning cable to an iTunes enabled computer. This will boot the device and then you can check for heat. If the heat signature is much better, then add back in one flex at a time (always disconnect the battery each cycle!). If the board is hot even with a bare bones setup, you probably have a logic board issue.
Punteggio 1
Aggiungi la tua risposta
Alexander Thomas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 157
