Salta al contenuto principale
A general-purpose audio device that transmits low audio frequencies to your ears.
What is this burned piece called
Punched my subwoofer cuz it wasnt working. I think it had blown voice coil. Semi worked then a few days later my stock amplifier from my 08 Mitsubishi lancer gts started smoking from under my seat. I took it out and opened it to find this. Can i take this piece out and fix it with a new one?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi Brian .... that is the power amplifier IC
are you good in soldering, for this .... If you have a hot air…. desolder it, note the part no and order replacement.
some idea for you to read……
e.g. troubleshoot, inspect, etc.
http://jestineyong.com/two-ics-burnt-in-...
Punteggio 1
Aggiungi la tua risposta
Brian Mcqueen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 140
