Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
iPhone 7: Error 53 after screen replacement (iOS 12)
Hi everyone. My iPhone 7 fell on the floor and the screen got smashed so bad it stopped displaying the image. Lickily, I had a perfectly working iPhone 7 lying around, so I just swapped the whole LCD assembly. The display turned on and displayed the restore required image. But, when I tried to restore, it would stop halfway and then produce the dreaded old error 53. Why is that? I tried DFU restore, replacing the battery, unhooking the rear cam and all combinations thereof. Please help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Did you transfer the Home Button from the damaged screen to the replacement screen? If you didn’t, that may be why you’re getting this message.
Punteggio 3
2 Commenti:
Thanks, didn't know that. I thought I would boot in and then proceed to transfer the home button. Will try now.
da
I tore the flex... :\ this is so embarrassing.
da
Aggiungi la tua risposta
koter sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 166
