Salta al contenuto principale
Processore quad core Intel Core i7 da 2,4, 2,7 o 2,8 GHz (3,8 GHz con Turbo Boost) con 6 MB di cache L3.
274 Domande Visualizza tutte
MBP Stopped Charging, No Mag Light
Just today, our MacBook Pro (15” Early 2013) stopped charging. I have tried two Apple Magsafe 2 power supplies with the same result. Neither lights up on the power supply connector, and there is no charging indication for the battery in MacOS.
For the last year or so, the battery has reported “Service Soon” or something similar. It doesn’t last long and is probably on it’s last leg.
Is the charging issue related to the battery or is this associated with internal electrical hardware?
Is the logic board responsible for the Magsafe operation and battery charging, or is there another electrical assembly that does this? I’m wondering what should be replaced - logic board, battery, or something else?
Below is an screenshot from coconutBattery.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
If the battery tells charging ic that its not safe to get charhed then sequence getting stopped. Try battery replacement first and then if its same thing post your logic board number
Punteggio 0
hello,
do you see green light all the time and won’t turn into red ?
Punteggio 0
Aggiungi la tua risposta
Jimmy M sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 51
