Salta al contenuto principale
This multimedia-geared dv6 comes with a 15.6-inch display, a built-in stereo, and weighs just under 7lbs. It is simple to disassemble- only a small screwdriver and a paper clip are required.
5 Domande Visualizza tutte
Hp pavilion m6 Caps lock blinking once after 3 secs no boot
Hi
2 days ago My hp pavilion m6 turned off suddenly for 2 3 times without warning. But it was able to turn on.
But today after a sudden turn off it is not turning on. Just gives a black screen, no fan etc. And Capslock keep on blinking once after 2 3 secs. And sometime it turns off after only one caps lock blink.
After sudden key combinations like pressing all arrows keys or alt+del+ctrl and power on. I am able to make caplock blink but on ac adapter capslock blink only once and laptop turns off. On ac adapter, there is no continuous capslock blinking just one caps lock blink and it turns off.
please help me.
Please help me here.
Questa è una buona domanda?
Punteggio 2
1 Commento:
Hi Affaq
Suggest you to access the RAM and if there are multiple RAM modules installed, take out out and test each at a time.
HP Pavilion dv6-2158nr RAM Replacement
da
Aggiungi un commento
1 Risposta
It is very possible that there is a short in the motherboard.
Things to try:
Reseat the RAM (memory)
Remove battery and hold the power button for 10 seconds. Plug the battery back in and then plug in the charger. Try again to turn on.
Punteggio 0
Aggiungi la tua risposta
Affaq Aslam sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,855
