Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
iPhone Vibrates after phone call + no sound heard by earspeaker
A customer of mine is having multiple issues with their device, no water damage, but screen is cracked. When they make a call, the ear speaker works sometimes when it's recently been rebooted, and the caller can hear them. They say it stops working after a couple minutes or more. The taptic engine also was not working, and when I opened the phone up, all three screws were loose to the taptic. When I tried to make a call, the vibrator would still shake after making the call.
Steps tried to solve the problem:
Restored
Disconnected and reconnect everything
Make call without taptic engine
Steps to try:
Replace front camera assembly with earpiece
Replace lightning port assembly
Replace Taptic engine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The iPhone 7 series of devices have proven to be very unreliable, suffering from flex-based issues similar to the iPhone 6 Plus (Touch Disease). On the iPhone 7, the fault line runs along the top of the SIM card reader and affects the Baseband CPU and Audio IC. Any short copper traces running perpendicular to the fault line while connecting to micro-BGA pads, is subject to failing.
On the Audio IC, this particularly affects the C12 pad/trace although there are 4 pads/traces along the fault line. Of those four, the C12 pad (I2S_AP_TO_CODEC_MCLK) is the most critical as it is a communication protocol line between the CPU and the Audio IC.
Here are the typical symptoms, as collated by the repair community:
  1. Voice Memos app / Loudspeaker on call - greyed out
  2. Siri doesn’t hear you / Caller can’t hear you
  3. Most other Audio related issues that aren’t solved by modular replacements
  4. Long boot times (3-5 minutes)
  5. iTunes detects the phone but stuck on the Apple Logo
  6. Haptic feedback on logo during boot
  7. Laggy Touch after PIN
This phone seems to exhibit some of the symptoms so if modular repairs don’t solve the issue, and Audio IC repair may be the next step.
Punteggio 2
Aggiungi la tua risposta
Cameron Nelms sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 57
