Salta al contenuto principale
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 Domande Visualizza tutte
Vizio d50u-d1 - flickering horizontal lines + duplication
Hello everyone! I’m wondering if anyone could help me with this problem. As the title says I’m experiencing some annoying flickering horizontal lines at the very bottom of my TV. These lines also seem to occasionally copy the image from the very top of the screen too. I know that horizontal lines are typically a panel issue but I haven’t seen all that much about the secondary issue with the lines copying the top of the screen elsewhere. I tried replacing the t-con to no avail so I decided to come here to see if anyone has some insight into what I could possibly do to solve the issue.
I have links to some pictures and videos of the issue here:
https://imgur.com/a/54jmZWE/
https://streamable.com/q5ziv
https://streamable.com/w6kk6
Thanks for looking and I look forward to any advice I can get!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@vizioproblems
remove the back of your set and check all the ribbon cables and connectors. Vizio has issues with cold solder joints on connectors. It does look like you are having gate driver issues on the LCD driver board (part of the LCD panel)
Punteggio 1
Aggiungi la tua risposta
Hugo Alighieri sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,056
