Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
Backlight keeps going out
The phone started by coming on after letting it sit for a while (it would have a small amount of light at the top of the display). After it finally came up, the phone would function for a while with the backlight flashing every now and then. Now I can get the screen to come on other than the faint light at the top of the screen.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
This is usually caused by either a loose connection from phone to screen, blown backlight circuit or liquid damage near the screen connector, or just simply a faulty screen needing replacement.
First thing I would try is reseating the screen cables, next inspect the screen connector on the board for physical damage or signs of wear and tear as this can cause a bad connection to the screen ribbon cables.
Worst case scenario, phone has liquid damage near screen connectors / backlight circuit blown meaning you would need to take the phone to a reputable repair shop that does board-repairs on iPhones.
Follow up to step 21 of this guide on how to unplug the screen cables:
Sostituzione schermo iPhone 6s
iPhone 6s Screen
Immagine Replace a screen compatible with iPhone 6s. Includes all of the small parts preinstalled in the assembly. Features a 4.7 inch, 750 x 1334 pixel IPS LCD Display, Front Camera Assembly, Earpiece Speaker, LCD Shield Plate, Cable Foam Pads, and Sensor Bracket.
Prodotto
iPhone 6s Screen
$54.99
Punteggio 2
Have you damaged the screen or attempted any repairs recently?
Sounds like a damaged Logic board, but coule just be the digitizer
Punteggio 0
Aggiungi la tua risposta
Gary Stevens sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 227
