Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1041 Domande Visualizza tutte
iPhone suddenly dim on upper left corner
Hello. My iphone is suddenly very dim (vignette) on the upper left corner. If I go 50% brightness, the upper left portion is stuck at around 15%. Just brought it 1 month ago from a friend, no issues until now.
I didn’t drop it or no water damage. It was fine when I put it on the bag and then when I try to use it again, the problem is already there. Sometimes when It will go back to normal when I put the brightness at 25 below.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Usually this is caused when the screen has been replaced (probably your friend had it done before) and the screen cables are not fully connected.
There are other rare causes where it is caused by the screen having a faulty backlight instead which would require getting the screen replaced to fix the problem.
Replugging the screen cables most of the time will fix this problem. If you are planning to reseat the screen connectors you must make sure to disconnect the battery first because the backlight circuit is very easy to blow up on the 6s models.
Follow up to step 19 of this guide which is where you unplug the screen display ribbon cable from the screen, the other cables do not need to be unplugged:
Sostituzione dello schermo dell'iPhone 6s Plus
Otherwise it’s a bigger issue with the screen connector on the board or the backlight circuit which either require taking the phone to a reputable shop that does board-level repairs / microsoldering to get it fixed.
TL-DR: First take it to a reputable phone repair shop to get them to try fix the problem via reseating screen cables first, then a screen replacement, last resort board level repair.
Punteggio 3
1 Commento:
Thanks for this. Btw to clarify, when I turn it off then on, it will go to normal if the screen brightness is around 25%. Then the dim corner will pop up if I go change the brightness.
da
Aggiungi la tua risposta
Joshua Pamintuan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 21
Tutti i Tempi: 2,309
